Originally Posted by calif67rt
I just looked up the dual carb setup. A manifold and gas lines are a little over $500 (not bad). But I can't afford the $3000 to $4000 they want for 2 carbs. So I will stay with a single carb until I can afford a new dual carb setup.
Leave those carbs for the resto guys.
A new set of Edelbrock 650 AVS Thunders will get the job done.
Banning put a set on a 572 street Hemi and it made over 770 HP.
NMCA NSS 67 Coronet
