Anyone else sell mounts that allow a late model 5.9 to go in 68 Abody?
Shouldn't that be the same as the 340 mounts?
If so transdapt makes a kit that will put it in a 68 A body that had a slant six.
If it's already a V8 car you existing mounts will work with a spacer on the driver's side if it's a 273/318 otherwise if it's a 340 then you can just use those.
