Your statement about V5 software leads me to believe that you loaded the wrong software on your computer. Delete the V5 software and load the Sniper software. You do not want to mix and match those two. Bad things will happen. I destroyed a $2000 Holley Dominator ECU by accidentally loading the wrong software on to it.
This is a brand new engine so 1. I think your right on software, I am clueless. 2. I will (use the Wizard) and take it somewhere that has done this, probably not local. Stephen
