I am installing studs in a stroked 340 block . I see a torque spec with ARP of 110. That sounds high to me What do you Torque the main Studs to ? What do you do for main Stud Locations at rear cap that interferes with oil pump installation ? Thank You
------------------------ It doesn't matter what you do.........As long as you look good doing it !
