Thats good of them to do that.
In the past ive used a arp stud and one of there thin nuts with 1/3 the top milled off both.
Other times ive just a std. oem bolt on that one side.
95 for me with arp lube as long as they are all the same and the machine work was all done with the same tq on the caps.
Shifting at 72-7400 with zero issues.
On the race blocks ive used 75-95 on the outter bolts and never seen a difference in the main bearings.
Hard area to really mess up on.
