The body of the oil pump Will hit the top of the stud and nut on the drivers side rear main . Also , I am trying to determine wheter to Torque the nuts on the Studs to the mopar bolt Spec of 85 or the 110 in the General ARP info .
------------------------ It doesn't matter what you do.........As long as you look good doing it !
