ARP main studs installation 340 with tray
#2608619
01/18/19 03:16 PM
01/18/19 03:16 PM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
I am installing studs in a stroked 340 block . I see a torque spec with ARP of 110. That sounds high to me What do you Torque the main Studs to ? What do you do for main Stud Locations at rear cap that interferes with oil pump installation ? Thank You
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: ARP main studs installation 340 with tray
[Re: doctor_mopar]
#2608703
01/18/19 06:30 PM
01/18/19 06:30 PM
RapidRobert
I was thinking that studs go in finger tight (lightly oiled) then the nut torqued to the correct ft lbs takes care of all the clamping. I had to lightly trim the pump for counterweight clearance iirc. what parts specifically are interfering?
[Re: doctor_mopar]
#2608716
01/18/19 06:45 PM
01/18/19 06:45 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I used an ARP bolt under the oil pump on my small block.
68 Barracuda Formula S 340
[Re: RapidRobert]
#2608730
01/18/19 07:27 PM
01/18/19 07:27 PM
doctor_mopar
Slidell, La.
The body of the oil pump Will hit the top of the stud and nut on the drivers side rear main . Also , I am trying to determine wheter to Torque the nuts on the Studs to the mopar bolt Spec of 85 or the 110 in the General ARP info .
[Re: doctor_mopar]
#2608739
01/18/19 07:59 PM
01/18/19 07:59 PM
Posts: 4,457 Washington
madscientist
Washington
I've used 95 on those studs for years with ARP lube or that peanut butter [censored] from Cummins or Cat or where ever it comes from.
I mill the cap down and use a short stud on the rear main so it doesn't interfere with the pump.
[Re: doctor_mopar]
#2608789
01/18/19 10:30 PM
01/18/19 10:30 PM
doctor_mopar
Slidell, La.
I called ARP . They are sending me two Bolts for the rear main cap , and Said to torque the nuts and bolts all to 110lbs ft with their special bolt lube on threads .
