Originally Posted By Nick Stevanovski
Another thing: alot of people were saying I would need a 2"+ compression height piston, but these are 1.867. How much does compression height matter after all of the other things have been worked out?
Read... the... books...
If you don't understand the implications of compression heights, you shouldn't be building anything. I'm done with this.
Ok then bye. But im clearly not building this myself. Hollis Page will be. I apologize for asking questions on a website meant for questions...
It's hard to communicate via the interweb, especially when the topic is as detailed as what you want.
On top of that, you are like a fart in a skillet. You are all over everywhere. I'm old enough to tell you've I've seen this before. You want to know it all, and know it now. It doesn't work that way. When you struggle with what compression distance is (nothing more that stroke length/rod length/ deck height) and mix things together, no one has any idea if you are actually teaching with what you are being told, or you are getting more confused.
You need to slow down and realize you won't learn this [censored] in a year. Or a decade. It's a lifetime of learning and it only stops when you quit or die.
You need to take this like eating an elephant...you do it one bite at a time. What you are doing is trying to take a sip from a fire hose. Read everything you can. Then reread it. It takes a lifetime.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
