With all of the variables in play and this seems to be your first build, you’d do a lot worse than calling or visting a local mopar shop. Todd marsh shouldn’t be all that far from you.
More good advice!!!
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
