Originally Posted By rb446
[quote=Nick Stevanovski]
440 source 500” stroker kit (flat tops, but dont know which, depends on how much overbore is needed, somewhere between 10.15? and 10.96 comp).....YES
Edelbrock rpm heads...NO TRICKFLOW.
Holley sd intake (is the street and strip dominator the same for the 440?)...SAME INTAKE, IDLE>6000RPM
800-850? holley vac sec carb....850DP AS YOUR MANUAL TRANS, MUCH BETTER...my2c.
Hydraulic roller cam (need suggestions, because from what ive heard from helpful people and complete a**holes, i need 250 @.050 to make around 550hp/600tq, and it shouldnt be really revving past 600, so would i need to try solid roller lifters for stability?).....DON'T NEED SOLID ROLLER, STD HYD OR HYD ROLLER 240>250@.050@500ci quite mild, MAX 6K RPM
1 3/4” hedman headers (or 1 7/8” if necessary, i dont want bigger simply to say theyre bigger)....1.7/8"
3” exhaust im assuming? Again not bigger just to be bigger, would 2.5” be too small?..2.5" OK, 3" LOUDER, LESS MPG
ARP head bolts and main studs...GOOD BUT NOT NECESSARY
Thank you so much. Was this so hard lol? Why couldnt anyone else do this? And why was everyone so bit*chy? I was asking for anawers. Not “ur an idiot”.
