Originally Posted By pittsburghracer
Originally Posted By StealthWedge67
CNC’d Stealth heads. Stock oiling.
I did this to my Sons car this year and its working out great with Harlan Sharp rockers on Edelbrock heads. It a small block but the same idea could be used. I tapped the rocker shaft oiling hole on both heads and screwed a brass set screw in with a .060 hole in it. That way if I wanted more or less oil I could simply remove the rocker shaft and go bigger or smaller. I bought a bag a brass set screws off ebay.
Im not up with small block but the oil comes up the sides of shaft hold bolt on big block.
1963 Plymouth Max Wedge
1971 Barracuda
