I started out with what I thought was way too much free play and then adjusted some of it out to make sure the clutch was disengaging. I didn't measure it but I would guess it was 4-5 inches initially, enough so the pedal wouldn't return all the way. The clutch shop says the clutch is fine. I will try to get it back in this week but I need to go through the transmission first.
