Thanks again for all of the pictures guys. Any more would be greatly appreciated.
Yes you can do it that way but make sure the pinion angle is correct with your weight in the seat and make sure the axle is square in the car. Have the stand under the axle housing
I don't have the perches welded on yet, so pinion angle adjustments will be easy.
Do I have to wait to do the ladder bars until the whole car is built to make sure every ounce of weight is on the car?
