Thanks for the pictures guys. I have one more question.
Since my car has leafs still, can I put the car up on jack stands and leave the leaf springs on to hold the rear where it goes and just tack all the ladder bar and coil over brackets to the housing? It seems like it would be a lot easier getting everything lined up that way.
And if you couldn't tell, tihs is my first ladder bar install.
Yes you can do it that way but make sure the pinion
angle is correct with your weight in the seat and
make sure the axle is square in the car. Have the
stand under the axle housing
