More band adjustments & the oil gets more contaminated.
I've witnessed zero wear. Adjustment has stayed consistent for over 100 passes. It's an A&A drum, Better material? Don't know. Fluid looks fine as well. Using JR 1 synthetic fluid. It's gone easy 100 passes on fluid and both it and the filter looked usable at that time. Doug
