Originally Posted By Spaceman Spiff
[quote=dvw][quote=racerx][quote=dthemi]A stock turbo 400 with a brake will take 700 hp almost till the end of time. A bell, some work on the mount, and forget
If you're breaking a 727 at 700hp something is wrong. A stock piece with a good valve body will last at that level.
Doug
I tore the splines out of the stock planateries, with about 600hp.
At what weight?
About 4600lbs.
Jesus Chrysler! runaway
'63 Dodge 330
11.19 @ 121 mph
Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft. 3,700 lbs.
