700hp is as piece of cake. Brake or no brake? No brake; old used turbo action VB. 4 plate front drum, aluminum one if you are scared of the factory piece. Early servo w/ inner and outer spring. 3.8 lever. Raybestos or Alto clutch frictions in the high drum, .012"-.015" per friction. You can run 5 frictions if you run the thin Altos. Not necesary at 700hp. Factory silver clutch frictions in the direct drum, .025"-.030". Solid red lined band. Deep 518 truck pan. Keep the end play tight. 3 pin planets are fine. This combo will go easy 500 passes before inspection. Running a brake? Add a steel front planet. If you're going to get a better low roller get the $200 dollar one from A &A, ATI, etc. You can fail even the better low roller.the standard bolt in are of no use unless your case is damaged. Don't be fooled. This combo works. My car runs the non brake set-up. 9.0@150 @ 3350 lbs. Currently 450 passes. Dizusters turbo car runs the trans brake set- up,9.52@142 @ 3750 lbs.
Doug
