Gj, my 92 2wd diesel scales at 5500# with just me and a tank of fuel. I'd suspect your 4wd would be closer to 6000.
And 4wwd would be a W250 That isn't my truck in the pic. It's from another forum. The guy builds houses in Mexico. My 92 CTD is a 2WD, my crew cab is a 4WD. But even at 5500# that is still over a 2 ton weight rating.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
