I know my 2016 1500 1/2 ton is actually rated over 1600 lbs (over 3/4 ton). I assume the 2500 has a similar "over-rating" .
- EM Yes they do, my D250 is rated at a GVR of 9800 pounds. These trucks only weigh about 5000 pounds empty.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
