I understand. Most scoops do not pull in anywhere near as much as as most people think they do anyway, unless you are running a legitimate huge ole Pro Stock scoop. This scoop will probably be 3" longer & at least 3-4" taller than a stock shaker scoop when done.
The openings will be raised slightly & will also be larger in size. It will pull more air than it looks now.
The base will mount with stanchions & feet to mount the intake or upper valve cover studs with some quick pins for ease of removal of the whole assembly for in between round maintenance when needed.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
