Hello -
This pic is from 2005, when I was taking the car apart. It looks MUCH nicer now, but the years have added to my confusion. I will hold the new photos until more complete
The car was missing the motor but trans was there. The single wire neutral safety switch wire was chopped off at the end, looks like it was pinched. Anyway, how is this wire routed? Does it drop off the right most firewall tab then straight down (highlighted in red)m then over the top of the trans to the switch?
Also there is a retaining tab also circled in red, where does this go, on bellhousing bolt?
Then on the other side of the firewall (blue circle), the grommet that plugs the manual washer hole (mine has power), is this a plastic or rubber plug? Not sure why, but mine was gone when I got the car. I have the body plug kit, but non fit this correctly. I measure a 1-3/8" hole. I have 1-1/4" and 1-1/2" in the kit, in plastic.
