Have you done a stroker in 2017? I imagine it is even more in 2018. I had a stock 340 short block built and heads done separately 3 years ago and it cost $5200 including parts by a very good shop then I assembled the rest. Hard to find cheap decent pistons and pretty much every part is twice what it used to be. Machining, buying parts, and assembling engines nowadays ain't cheap!
