Re: Is it reall 8to 10K to build a mild 383 bb now a days?
[Re: Black 69 Beeper]
#2432138
01/10/18 12:31 PM
01/10/18 12:31 PM
Posts: 2,686 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Thing is I just want a fairly stock 383. Its a 4 speed, factory exhaust manifolds, and I have to run the factory intake to clear the air grabber. I'm not looking for a speed demon. All I wanted was a 383-4 speed-3:55 posi car. original equipment. Seems like most everyone on this board isn't listening to you. They all want you to build a $12,000 aluminum head stroker motor. (I like those too.) Your build should cost almost nothing. I can't believe you can't find a complete running 383 for what you paid to tear your motor down. Used 383 rods are free. People throw them outside. 906 heads are nearly free. Might cost a 2 digit number. What you are wanting to build can be done for a little of nothing if you find some good ole Mopar boys that have had that garbage sitting around forever and know they are never going to use it. And from looking at the stage your car is in it looks like you have some time to shop for bargains. Happy hunting.
2011 Drag Pak Challenger
[Re: rickseeman]
#2432143
01/10/18 12:44 PM
01/10/18 12:44 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Thing is I just want a fairly stock 383. Its a 4 speed, factory exhaust manifolds, and I have to run the factory intake to clear the air grabber. I'm not looking for a speed demon. All I wanted was a 383-4 speed-3:55 posi car. original equipment. Seems like most everyone on this board isn't listening to you. They all want you to build a $12,000 aluminum head stroker motor. (I like those too.) Your build should cost almost nothing. I can't believe you can't find a complete running 383 for what you paid to tear your motor down. Used 383 rods are free. People throw them outside. 906 heads are nearly free. Might cost a 2 digit number. What you are wanting to build can be done for a little of nothing if you find some good ole Mopar boys that have had that garbage sitting around forever and know they are never going to use it. And from looking at the stage your car is in it looks like you have some time to shop for bargains. Happy hunting. YOu aren;t listening to him either. He wants a stroker 383, assembled and dynoed for him. No way will that be some bargain, dirt cheap deal. If he was building the stock 383 you seem to think he wants, then yeah it could be a cheap deal if he could scrounge the parts and didn't go crazy on machine work. This means he builds it, not someone else builds it for him.
[Re: Supercuda]
#2432146
01/10/18 12:50 PM
01/10/18 12:50 PM
Posts: 16,163 Mesa, Arizona
dart4forte
Mesa, Arizona
Most Ive ever paid for a 383 was 4K. 6K for a 451 stroker.
Abe Lincoln
#2432176
01/10/18 01:52 PM
01/10/18 01:52 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
There was a fresh,warmed over, stock appearing 383 with auto trans, k frame, complete disc brake set up that came out of a 69 roadrunner for 4,500. Guy went with a hellcat conversion.
I could check, but Im fairly certain its long gone being that was back in october
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
#2432180
01/10/18 02:00 PM
01/10/18 02:00 PM
fast68plymouth
So. Burlington, Vt.
IMO...... The real first step in this process is figuring just what the budget for the complete motor is(carb to pan, dist, wires, plugs, oil, everything), and see if what you "want" for an engine combo can be done competently for that amount of money. Sometimes(often times), the budget and the desires aren't on the same page(filet mignon tastes with a McD's budget).
In that situation, the budget or the build goals need to be adjusted to make it all work.
In the end, it usually comes down to what can you spend....... And what's the best build you can do for your requirements that will fit within your budget.
[Re: rickseeman]
#2432181
01/10/18 02:00 PM
01/10/18 02:00 PM
Posts: 31,082 Oregon
AndyF
Thing is I just want a fairly stock 383. Its a 4 speed, factory exhaust manifolds, and I have to run the factory intake to clear the air grabber. I'm not looking for a speed demon. All I wanted was a 383-4 speed-3:55 posi car. original equipment. Seems like most everyone on this board isn't listening to you. They all want you to build a $12,000 aluminum head stroker motor. (I like those too.) Your build should cost almost nothing. I can't believe you can't find a complete running 383 for what you paid to tear your motor down. Used 383 rods are free. People throw them outside. 906 heads are nearly free. Might cost a 2 digit number. What you are wanting to build can be done for a little of nothing if you find some good ole Mopar boys that have had that garbage sitting around forever and know they are never going to use it. And from looking at the stage your car is in it looks like you have some time to shop for bargains. Happy hunting. You are correct that 906 heads are cheap and 383 rods are often free. I've thrown away boxes of 383 rods so if someone was standing next to the dumpster I would've gladly handed them the rods if they wanted them. I just gave away a 400 cast crank the other day and probably have another one in the shop that I'd give away. So sure, someone could show up at my shop with $500 and drive away with rods, crank, block and heads to build a 383. But somehow I don't think that is the point of the thread. If the guy who bought all of my throw away parts takes them to a race engine builder who is swamped with work the story doesn't end well. Nobody who builds race engines for a living wants to mess around with a bunch of 50 year old parts that a guy drags in. Especially if the engine builder has a wait list 30 guys deep who want drag race or circle track engines ready for spring. It just isn't going to happen. Now maybe the OP can find an older guy in the back of the local NAPA store who operates at a slower pace and doesn't mind futzing around rebuilding 383 rods and putting new seats in some old 906 heads. Those guys are around but you have to search a little bit to find them. Best advice I have is that if someone wants a stock rebuild type of engine and they want it done right for very little money then they need to ask around at some local car clubs for a name. There are retired guys out there who don't mind working for $20 an hour putting together old engines. But I don't think you're going to find cheap labor at a busy race shop. You are either going to get a high quote, or no quote at all.
#2432187
01/10/18 02:11 PM
01/10/18 02:11 PM
fast68plymouth
So. Burlington, Vt.
Now maybe the OP can find an older guy in the back of the local NAPA store who operates at a slower pace and doesn't mind futzing around rebuilding 383 rods and putting new seats in some old 906 heads. Those guys are around but you have to search a little bit to find them. I don't mind putting seats in 906 heads at all. ![apimp apimp](/ubbthreads/images/graemlins/custom/apimp.gif) I'll be shipping out a nice set of rebuilt 906's today that are destined for a Daytona Charger. More $$$ than RPM heads....... But these are really what should be on that car. I don't mind rebuilding stock heads at all....... But it's often not the least expensive path. Just because the heads are old doesn't mean the shop labor rate is any less.
[Re: fast68plymouth]
#2432191
01/10/18 02:21 PM
01/10/18 02:21 PM
AndyF
Now maybe the OP can find an older guy in the back of the local NAPA store who operates at a slower pace and doesn't mind futzing around rebuilding 383 rods and putting new seats in some old 906 heads. Those guys are around but you have to search a little bit to find them. I don't mind putting seats in 906 heads at all. ![apimp apimp](/ubbthreads/images/graemlins/custom/apimp.gif) I'll be shipping out a nice set of rebuilt 906's today that are destined for a Daytona Charger. More $$$ than RPM heads....... But these are really what should be on that car. I don't mind rebuilding stock heads at all....... But it's often not the least expensive path. Just because the heads are old doesn't mean the shop labor rate is any less. Exactly, that is my point. The OP can find a shop that will rebuild his old engine but it is going to cost as much or more than if he bought new parts. On the flip side, I recently came across a retired machinist in the local area who rebuilds transmissions for $300 plus parts. He operates out of his own garage shop so overhead is low and he takes his time but does a good job. So guys like that are around, but finding them can be a little difficult since they don't spend money on advertising.
#2432227
01/10/18 03:24 PM
01/10/18 03:24 PM
Posts: 24 Massachusetts
ericlre79
Massachusetts
Like a 383 stock eliminator motor as seen in my original 4 speed 70 383 Challenger RT/SE? I might want to switch to a different combo, maybe a 440 or a 340 as the cost to build good motors are all roughly the same. You might want to get in touch with me!
Eric
#2432329
01/10/18 05:59 PM
01/10/18 05:59 PM
fast68plymouth
So. Burlington, Vt.
Im not sure what "napa" machine shops you guys know of but my local on has 11 full time workers in the machine shop and very modern equipment and are always a month out. What's the shop labor rate there? Modern equipment is expensive, and so are employees, so I doubt they're working for peanuts. Be interesting to hear an estimate on a build like this: 383 Engine kit with trw 2315's and upgraded cam. Strip and clean block Deck block Torque and check rods Torque and check mains Bore and hone Grind crank Balance rotating assy Recondition heads w-hp springs and hardened ex seats Clean all tin, rocker gear, intake, pulleys, etc Then add $1500-2000 for a complete assy and dyno test(since that's what the OP says he wants).
[Re: rickseeman]
#2432377
01/10/18 07:18 PM
01/10/18 07:18 PM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
Thing is I just want a fairly stock 383. Its a 4 speed, factory exhaust manifolds, and I have to run the factory intake to clear the air grabber. I'm not looking for a speed demon. All I wanted was a 383-4 speed-3:55 posi car. original equipment. Seems like most everyone on this board isn't listening to you. They all want you to build a $12,000 aluminum head stroker motor. (I like those too.) Your build should cost almost nothing. I can't believe you can't find a complete running 383 for what you paid to tear your motor down. Used 383 rods are free. People throw them outside. 906 heads are nearly free. Might cost a 2 digit number. What you are wanting to build can be done for a little of nothing if you find some good ole Mopar boys that have had that garbage sitting around forever and know they are never going to use it. And from looking at the stage your car is in it looks like you have some time to shop for bargains. Happy hunting. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) This isn't a high dollar build here. If you were closer, I'd be happy to tackle this job for you and give you a run stand tested motor that's ready to drop in.
[Re: rickseeman]
#2432464
01/10/18 09:46 PM
01/10/18 09:46 PM
Posts: 4,321 Prospect, PA
BSB67
Prospect, PA
Thing is I just want a fairly stock 383. Its a 4 speed, factory exhaust manifolds, and I have to run the factory intake to clear the air grabber. I'm not looking for a speed demon. All I wanted was a 383-4 speed-3:55 posi car. original equipment. Seems like most everyone on this board isn't listening to you. They all want you to build a $12,000 aluminum head stroker motor. (I like those too.) Your build should cost almost nothing. I can't believe you can't find a complete running 383 for what you paid to tear your motor down. Used 383 rods are free. People throw them outside. 906 heads are nearly free. Might cost a 2 digit number. What you are wanting to build can be done for a little of nothing if you find some good ole Mopar boys that have had that garbage sitting around forever and know they are never going to use it. And from looking at the stage your car is in it looks like you have some time to shop for bargains. Happy hunting. I think your miss what some have said. Its not that it has to cost that much, it just finding someone competent to do it.
[Re: Mr.Yuck]
#2432673
01/11/18 05:37 AM
01/11/18 05:37 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
No it takes 5500-6000. At least from me it does.
Block,heads,int etc cleaned Deck Squared and cut to 0 deck depending on piston. Align hone Honed with plates Balance assy Crank repaired as needed. Recondition con rods w/arp bolts oil pump dr shaft bushing. All clearances checked and assemble eng. Cam c/l checked and degreed Cam broke in on run stand, usually about 2 hrs of run time
Iron cyl heads comp rebuilt incl guides and hard exh seats CC to comp ratio choosen. Usually 9.5 for 93 octane
New perf bearings incl cam [Clevite or King],custom (Icon) forged pistons and moly rings Hastings or Total seal. New Cam, Lunati,Comp,SP or Mopar. Hyd lifters and new pushrods New SP rockers and shafts New Timing set roller New mopar perf oil pump dr New melling oil pump New manley valve springs and hardened valve locks. New superformance and fel pro seals and gaskets.
I prob forgot a couple things but basically that is the package.
440 engines are about 500.00 more. Taking orders now for next season. Tons of options available.
Leave the gun.......take the Cannoli's....Mike
