Originally Posted By 69 lawndart
At this point in time the aluminum Ritter block in mine has been great, no problems. WhiteDart are you feeding the oil into the motor on the front China wall? I drilled and taped the hole between the upper and lower oil gallies and put a restricter in to slow the oil down going to the top end. I am feeding mine through the back of the block.
when you say at this point in time.. is that because you have had bearing issues also??.. how many passes has it been happy.. mine is restricted at the bushing.. I thought you were running bushings as well
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
