I’m window shopping too but it probably won’t happen this Winter. It sounds like the big block mopar Harlan Sharp rockers may work on these heads if I’m reading right. See when you get from the info they have on the Jegs website as they must be the mininum offset needed. Custom pistons for sure and to make them worthwhile an R3 block should be used with a nice big roller cam
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
