At this point in time the aluminum Ritter block in mine has been great, no problems. WhiteDart are you feeding the oil into the motor on the front China wall? I drilled and taped the hole between the upper and lower oil gallies and put a restricter in to slow the oil down going to the top end. I am feeding mine through the back of the block.
