Disconnect the TP linkage at the trans lever and see if it shifts through all gears and downshifts at a stop. If it does, the linkage adjustment/installation is wrong.
Which carb? If aftermarket does it have the correct Mopar throttle lever extension?
The INTERNET, the MISinformation superhighway
