Check.
Test Drive kind of confirms what I'm thinking.
Stayed in 1st a really long time, wound up to 3000rpm, lightest throttle, backed off and finally got into second. No upshift to third, again went to 3000rpm about 40 mph.
Slowing down to a stop, no downshift felt. Confirmed, started off in second. Eventually found first again but not regularly downshifting.
When checking Governor pressure on the jack stands, I did see pressure going up with speed - maybe 15-20psi at 40mph. But I did notice some pressure at full stop in drive, hard to say but maybe 5psi. I know thats not correct - and probably explains not downshifting - but what about upshifting?
