Originally Posted By RapidRobert
It still vibrates the same even in park or nuetral.
unless it is an ign misfire & I have my doubts, it is strickly eng related, are you sure the right TC/dampener are on there? unless the factory balancing is way off but I'd think the above first.
Yes I can post pictures of them if you'd like me to.
I've verified the converter is the correct converter for the 360 magnum, it's dark maroonish red with the weight on the one side of it.
The flex plate is an La style flex plate.
I tried posting pics and it wants me to use a URL?
