As soon as I get my rear end back together and my driveshaft is done I will get a pic of the tires on the car. Right now I'm getting the rear end re-tubed and trued up. Like I said already they BARELY fit and I'm pretty sure that if I didn't turn my shocks up to max they would rub the outside wheel tub.I think with a little massaging they would clear or if I would move the springs in and go with a 4 1/2" backspace wheel. I have 3/4" clearance to the spring with a 4" backspace 8" wheel.
Should have my junk back together in a few weeks and I will get a picture then.
Gus
