Measured my car yesterday, and I have well over 1/2" clearance to the leaf spring, and toward the quarter panel wheel opening, so they would most likely fit, but would be snug. The extra inch of tire diameter should be ok, the Hurst Piecrust tires are over 29 inches tall. Only concern really is the clearance on the outside top section of the wheel tub. Looks like the tire may rub slightly with suspension travel upward. Just wondering if anyone else has attempted this before with success.
