Originally Posted By 1964superstock
Originally Posted By fourgearsavoy
The 295 will fit MY 64 Savoy with a 8" rim with 4" back space but it might rub when the body comes down. the Hoosier has a 12.3" max sidewall width with a 10" tread patch.
I will try to drive it down the road when the weather gets better around here.
Gus beer
Thanks for your reply. I would love to see some photos of the 295 65 15 Hoosiers on your '64 Savoy. Are you running leaf springs in stock location? Stock wheel tubs? Stock width rear axle? What is the width and back space on the rear wheels are your using?
Hoosiers are 1/2 inch shorter then the Mickey's.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
