The 295 will fit MY 64 Savoy with a 8" rim with 4" back space but it might rub when the body comes down. the Hoosier has a 12.3" max sidewall width with a 10" tread patch.
I will try to drive it down the road when the weather gets better around here.
Gus
Thanks for your reply. I would love to see some photos of the 295 65 15 Hoosiers on your '64 Savoy. Are you running leaf springs in stock location? Stock wheel tubs? Stock width rear axle? What is the width and back space on the rear wheels are your using?
My springs are in the stock location,wheel tubs stock,rear axle is very close to a 67 B rear axle width.It was under a 67 Camaro with Moser axles
It fit so I traded my 9" for it. I only have one tire and wheel combo so I could test fit it before I buy a pair of them. The rim is a Basset IMCA rim 8" wide with a 4" backspace.
I will mount the wheel and get a pic of it this weekend.
Gus
