Do any of you guys know if the OBD2 ECU has to see the Can-bus/gauges to work? If so, is there a fix to not use it? I want to run manual gauges in my old truck, with the sensors the ECU needs to see plumbed in also. I apologize to the OP for the hijack but lots of good info is coming out in this thread.
