Yes. I'm not sure I follow you on what taking it off the idle circuit by raising the rods is going to tell us. My other thought is to bump the timing by 2 deg and see what that does. If it doesn't detonate I don't see what it will hurt. I guess its a chicken or egg situation. Is it idling down because the rods are bouncing or are the rods bouncing because the idle drops?
