Thank you challenger 73400 for posting (and 5280 Dart). I am so glad to have found this site and your posts.
I am starting on a similar project on ‘56 two door wagon (Plodge) this spring using a ‘92 dakota frame clip and magnum engine.
Do you think that if I (you) used the dropped spindles right off the get go, the front frame rails would be where you want them?
Please continue to post your progress and pictures, and once again, thank you for posting, You probably have a good idea of how invaluable and important posts of this kind are. up
