The solenoids weren't covered, just the pressure switches and the (you will need to add them) relays. I assumed the L/U and O/D solenoids always have keyed 12v to them and you switch the ground side to turn them on and off.
They say there are no such thing as a stupid question. They say there is always the exception that proves the rule. Don't be the exception.
