I tried to make sure the frame sections overlapped each other by a value nearly equal to the dimensions of the tubing. In other words if one section of frame was made of 3x5, I overlapped the sections by 5". I welded the portions of the frames together that matched up, which was not much as the dakota frame is narrower than the '57 and also positions higher when at factory ride height. I then used 3/16" plate to bridge across from one frame section to the other. I used an oxyacetylene rosebud, a vise, and hammer to form the plate steel pieces into rough shape, and then tacked and welded the pieces into position using large C-clamps, heat, and hammer for final shape.
Making sure you position the kick up from the parent frame to the dakota far enough forward as to avoid interference with the firewall is important.
