I parallel the top of the oil pan... that will put you over the K-member.. but I run hard line.. if this is a 904 or 727 its 5/16 tubing.. a 518 type uses 3/8 tubing... also if running headers the lines can get close to the headers so I run a thermo barrier that slides over the tubing... its good for over 1000*.. works fine on my Rampage.. keep it tight to the pan
