Monte...well I talked with Jegs Tech support and he told me that 4 out of 10 Holley efi items that they sell comes back due to poor satisfaction. He also told me that the Billet throttle body is much better because of better throttle plate/shaft tolerances, and the cast ones come back with broken ears and are loose.
I was trying to get information on the new Holley EFI programmer/dash unit, because the 5.7" display unit is $716.00 and the new unit is $799.00 and has a bigger screen.
Since I do not have a laptop, I was interested in the programmer with the most features.
Any advice on your end?
Thank you, Mark
That guy at Jegs is FULL OF IT... I have the Holley Dominator
and love it... bolt it on and set the program in your computer
in your case you will have to take the whole computer out to
the shop.. program it and use the computer to monitor it in the
shop... they did forget 1 small plug but when I talked to the
Holley tech he said what I was missing and sent it right out
and I had it fired up on the second day...then let it learn..
its been running great and it does have a ton of power... its
quicker than my carb set up on the revs
EDIT
I bought mine through Monte.. he saved me a pile full
of money just on the hand held read out that I thought
I had to have... he said the lap top is all he uses..
so thats all I use on mine.... and for the price of lap
tops its worth the price to get a lap top... JMO
