OK, wasn't sure what I had. I bought the water pump pulley that Megaparts sells for 66-68 I believe. It is shorter and doesn't come close to the water pump bolts, so when I pull the dampner back where is should be they will probably line-up.
I didn't see one listed for 66-68 , only 68-71 ???
