I am mocking-up my 426 Hemi without the rods and pistons but put the crank in with the old bearings and tightened the caps down. The crank turns freely but when I put the dampner on it hits the new Milodan oil pan where it bolts to the timing cover. The pulley's don't line up either, but I don't know if I have the correct ones yet. Anyone run into this issue? shruggy
JB Rhinehart, Realist
A-Body's RULE!
