Exactly, a couple of graphs with no explanation of what they are does not prove or disprove anything.
If you want to see ram air in action then call a Pro Stock team and ask them for a pressure reading from the air box during a 1/4 mile run. Or call up a NASCAR team and ask them the same info. Or to make it simple call Dave Braswell and ask him how much air pressure a Pro Stock carb sees in the lights and how it changes the AF ratio.
if you have contactinfo i'd call! i'd be curious to see exactly whats going on. Thanks good Sir.
When it takes more than a sweet mullet to prove you rule at the trailer park..
