Now a days the manometer has been changed out for a map sensor mounted in the scoop/carb plate area. Makes it very easy to see if the pressure is above or below atmospheric. If you haven't done this you're just not as dedicated as some other racers. It's always easy to talk theory, results speak for themselves. Doug
