Cool air = better than hot air. In fact I'm surprised that after all these years of hotrodding, the standard open element 4 barrel air cleaner sucking in hot under hood air is still the gold standard.
As far as any ram effect goes, even IF you did get a smidge of pressure off it, at best it would help to overcome the resistance of the air filter. The carb is not going to see pressure.
