Is that case size frt to back and does include the pulley. I measured the Toyota I have and got 4-7/8 frr to back and 5-3/4 with pulley.
if you are asking me, I measured the diameter of the round part of the alternator body
My problem is the depth.I
Have a new Toyota alt but if I can fit the bigger one I may go that route on the dohn Deere one you sell.
I had that issue when I had my motor plate, maybe you do too? When I was running an alternator off my motor plate I ran one of these. It's a GM alternator CS130D (D is for double internal fan, gving better cooling) they also work much better than the CS130 that many people use because it use larger bearings. Small bearings have been known to have been a issue on the CS130. I spaced out the long ear to pivot under the motor plate,
keeping it out of the way. Stock 105 amp.
