I just got the 60 amp one from a friend like new. It says 60 idle 80 at 4500 on tag is that why u guys running. I have msd electric fuel and a big spal fan I am also doing the electric water pump deal. The fan is the big sucker at 25 amps
That sounds like the Viper 2 speed fan on low.. I use the 85A Denso with a external regulator... I prefer the external regulator.. why trash a alt because of the regulator went bad.. plus its a easy test to see if the alt is putting out
