I have 1 brand new 14611 left ($90 plus the ride), for $110 I can make it a 1 wire where you only need to run the battery cable, or make it 16 volt wire wire for the same. But I won't have more 16 volt regs for a week. If they ever go bad like P-body says, it only takes a couple Phillips screws to change them under the cover
