Originally Posted By MR_P_BODY
Originally Posted By GY3
Originally Posted By 493_DART
I bought one of these kits for the stock alt. ---seems to work great
http://store.alternatorparts.com/ho7005-chrysler-square-back-alternator-80-amp-upgrade-kit-1.aspx
I need to do SOMETHING. I'm tired of the dim lights at idle. I'm not sure I want to rewire the whole dang car, though. The jumper from the alternator to the starter doesn't bother me but...
A simple fix is to use the halagon lights.. you
dont need to rewire.. they draw way less.. but a
new style alt helps out.. I run the denso 85a and
run a lot of elec stuff and injection... the volts
set at 14.7 at idle
EDIT
I run this light on my Rampage.. its bright and
has a perimeter of white leds and a inner small
light that I also have hooked up to my turn signal
wave
That`s a great idea...........I have the older halogens which help but that may be my next step if they`re that much better...........
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
