I will now be looking for running motors when I do this sort of build again.
$183 to re-ring and put new bearings in a good motor has turned into $900 For new pistons, rods, rings, bearings, crank grind, not to mention $300 in machine labor to bore +30; hot tank; R&R cam bearings.
